跳转到主内容
帮助
LG VX3100 Keypad Replacement
令人困惑的文字
令人困惑的文字
本指南的一些文字是混乱的,重复的,或偏离主题。请通过编辑使其明确!
  • 作者: Tyler
  • 估计时间: 30分钟
  • 难度: 中等
Buttons bit the dust? Resurrect them with a new keypad by following this simple repair guide:
工具
相关配件
步骤 1 Keypad  ¶
Use a T7 Torx screwdriver to remove the four screws that are located underneath the area where the battery was.
步骤 1 Keypad  ¶
  • Use a T7 Torx screwdriver to remove the four screws that are located underneath the area where the battery was.
步骤 2  ¶
Be careful when removing the casing as the spudger can damage the plastic cover of the phone. Use the spudger to carefully pry around the sides of the plastic casing and remove the back side of the phone. Use the spudger to carefully pry around the sides of the plastic casing and remove the back side of the phone.
步骤 2  ¶
  • Be careful when removing the casing as the spudger can damage the plastic cover of the phone.
  • Use the spudger to carefully pry around the sides of the plastic casing and remove the back side of the phone.
步骤 3  ¶
Use the spudger to remove the back side of the phone. The logic board is still connected to the rest of the phone with a gold strip; be careful when removing the board. Use the spudger to gently push the keypad out from the other side of the phone.
步骤 3  ¶
  • Use the spudger to remove the back side of the phone.
  • The logic board is still connected to the rest of the phone with a gold strip; be careful when removing the board.
  • Use the spudger to gently push the keypad out from the other side of the phone.
