跳转到主内容
帮助
Disassembling iRobot Roomba 551 Bumper
This guide will allow you to take the bumper off of the iRobot Roomba 551.
  • 作者: Cody Rhoads
  • 估计时间: 10 - 20 分钟
  • 难度: 中等
This guide explains how to remove the bumper from your Roomba.
步骤 1 Bumper  ¶
With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper. With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper. With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
步骤 1 Bumper  ¶
  • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
步骤 2  ¶
Lift the bottom cover and set it to the side.
步骤 2  ¶
  • Lift the bottom cover and set it to the side.
步骤 3  ¶
Flip the Roomba over, grasp the bumper, and gently lift to remove. The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
步骤 3  ¶
  • Flip the Roomba over, grasp the bumper, and gently lift to remove.
  • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
