跳转到主内容
帮助
Samsung SPH-A640 Screen Replacement
需要更好的图片
需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片​​!
缺失步骤
缺失步骤
糟糕!本指南目前缺少一些重要的步骤。
Replace the screen of your Samsung SPH-A640.
This guide will provide the steps necessary for replacing the screen in the Samsung SPH-A640 cellular telephone.
工具
步骤 1 Screen  ¶
Using a #00 Phillips screwdriver, remove four screws from the bottom half of the phone in the battery compartment. The screws are in each corner. Place screws off to the side.
步骤 1 Screen  ¶
  • Using a #00 Phillips screwdriver, remove four screws from the bottom half of the phone in the battery compartment. The screws are in each corner. Place screws off to the side.
步骤 2  ¶
Using a plastic opening tool, pry off back cover starting at the bottom corners and moving around the perimeter towards the hinge.
步骤 2  ¶
  • Using a plastic opening tool, pry off back cover starting at the bottom corners and moving around the perimeter towards the hinge.
  • Disengaging the clips near the hinge may require some force.
步骤 3  ¶
Using tweezers, carefully remove the buttons from both sides while removing the back cover.
步骤 3  ¶
  • Using tweezers, carefully remove the buttons from both sides while removing the back cover.
  • Note the positions of the buttons. They must be returned to the same positions.
步骤 4  ¶
Once the back is removed, use a plastic opening tool to disconnect the electrical connector near the hinge.
步骤 4  ¶
  • Once the back is removed, use a plastic opening tool to disconnect the electrical connector near the hinge.
步骤 5  ¶
Peel off the screw covers and remove two exposed Phillips head screws with a small Phillips head screwdriver.
步骤 5  ¶
  • Peel off the screw covers and remove two exposed Phillips head screws with a small Phillips head screwdriver.
步骤 6  ¶
Remove the front cover of the phone using a plastic opening tool.
步骤 6  ¶
  • Remove the front cover of the phone using a plastic opening tool.
  • Slide a plastic opening tool along the seam from the hinge around the perimeter.
步骤 7  ¶
Using a plastic opening tool, disconnect the electrical connector. The electrical connector is located near the hinge and is revealed when the front cover is removed.
步骤 7  ¶
  • Using a plastic opening tool, disconnect the electrical connector. The electrical connector is located near the hinge and is revealed when the front cover is removed.
步骤 8  ¶
Using a plastic opening tool, pry the speakers from the case. These are located at the top of the back of the phone. Using a plastic opening tool, pry the speakers from the case. These are located at the top of the back of the phone.
步骤 8  ¶
  • Using a plastic opening tool, pry the speakers from the case. These are located at the top of the back of the phone.
步骤 9  ¶
Using a plastic opening tool, lift the screen assembly from the case. Using a plastic opening tool, lift the screen assembly from the case.
步骤 9  ¶
  • Using a plastic opening tool, lift the screen assembly from the case.
步骤 10  ¶
没有图片
步骤 10  ¶
  • To the best of our knowledge, remove the hinge to free the ribbon cable from the case and remove the screen assembly.
