跳转到主内容
帮助
Imation Superdisk USB Drive Plastic Housing Replacement
要点符号!
要点符号!
更好地协调标记与要点符号的颜色和类型将有助于使本指南更清楚!
更好的介绍
更好的介绍
通过完成或修改其开头介绍以改善本指南。
缺少细节
缺少细节
本指南有些细节缺失。请通过添加所需工具、难度或所需时间来帮助用户。
This guide will show you how to remove the plastic housing shell of the Imation Superdisk USB Drive. Removing this shell will allow you to access the interior workings of the drive.
步骤 1 Plastic Housing  ¶
Flip the device over so the bottom is facing up. You will know it is the bottom because there will be six silver screws visible.
  • Flip the device over so the bottom is facing up.
  • You will know it is the bottom because there will be six silver screws visible.
步骤 2  ¶
Remove the USB converter device by gently pulling it out. Do not pull the converter device out by the cord.
步骤 2  ¶
  • Remove the USB converter device by gently pulling it out.
  • Do not pull the converter device out by the cord.
步骤 3  ¶
Remove the six silver screws using a small Phillips head screwdriver. Remove the six silver screws using a small Phillips head screwdriver.
步骤 3  ¶
  • Remove the six silver screws using a small Phillips head screwdriver.
步骤 4  ¶
Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel. Lift panel free of device.
步骤 4  ¶
  • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
  • Lift panel free of device.
步骤 5  ¶
Remove the plastic end cap by sliding it forward, freeing from the rest of the device. You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
步骤 5  ¶
  • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
  • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
步骤 6  ¶
Slide the metal housing out of the plastic shell. Slide the metal housing out of the plastic shell.
步骤 6  ¶
  • Slide the metal housing out of the plastic shell.
