跳转到主内容
帮助
Snowboard Binding Strap Replacement
特色学生指南
特色学生指南
该指南是我们优秀学生的辛勤劳动的成果,iFixit的工作人员认为这个很酷。
特色指南
特色指南
iFixit的工作人员认为该指南特别酷。
Maybe the most common thing to break on your snowboard is a binding strap. Fear not, replacing straps are easy and cost effective. This guide will show you how to replace the various straps on a Union Force Binding.
  • 作者: Robert Torres
  • 估计时间: 15 - 20 分钟
  • 难度: 中等
The purpose of this guide is to show you how to remove/replace all of the straps on your bindings. However, you do not need to remove the toe straps to replace the ankle straps and vice versa. Begin this repair guide at the appropriate step relevant to your problem.
步骤 1 Binding Strap  ¶
Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding. Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding. Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding.
  • Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding.
  • Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding.
步骤 2  ¶
Unscrew the 10mm long thumb screw connecting the heel strap with its binding connector. Pull the heel strap apart from its binding connector.
步骤 2  ¶
  • Unscrew the 10mm long thumb screw connecting the heel strap with its binding connector.
  • Pull the heel strap apart from its binding connector.
步骤 3  ¶
Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding. Using a Phillips #2 screwdriver, locate and unscrew the countersunk ovalhead M4 x 16mm screw holding the heel strap connector to the binding. Using a Phillips #2 screwdriver, locate and unscrew the countersunk ovalhead M4 x 16mm screw holding the heel strap connector to the binding.
步骤 3  ¶
  • Using a Phillips #2 screwdriver, locate and unscrew the countersunk ovalhead M4 x 16mm screw holding the heel strap connector to the binding.
步骤 4  ¶
Flip the binding so that the bottom is accessible. Using your hands, pry off the plastic bottom covering starting at the toe end.
步骤 4  ¶
  • Flip the binding so that the bottom is accessible.
  • Using your hands, pry off the plastic bottom covering starting at the toe end.
  • The bottom may still remain attached on the heel edge. There is no need to completely remove it.
步骤 5  ¶
Remove the corner foam coverings by grabbing one edge and lifting up. Slide out the toe strap ladder. Slide out the toe strap ladder.
步骤 5  ¶
  • Remove the corner foam coverings by grabbing one edge and lifting up.
  • Slide out the toe strap ladder.
步骤 6  ¶
Using a Phillips #2 screwdriver, unscrew the button head M4 x 10mm screw holding the toe strap with its connector. Slide the toe strap off of the toe strap connector. Slide the toe strap off of the toe strap connector.
步骤 6  ¶
  • Using a Phillips #2 screwdriver, unscrew the button head M4 x 10mm screw holding the toe strap with its connector.
  • Slide the toe strap off of the toe strap connector.
步骤 7  ¶
Turn the binding on its side and slide out the toe strap connector. Turn the binding on its side and slide out the toe strap connector.
步骤 7  ¶
  • Turn the binding on its side and slide out the toe strap connector.
