跳转到主内容
帮助
iPhone 5c Screen Replacement
Replace the screen on your iPhone 5c.
  • 作者: Walter Galan
  • 估计时间: 5 - 20 分钟
  • 难度: 中等
Learn how to replace your iPhone 5c screen. This part comes with the front-facing camera, earpiece speaker and sensor cable already installed, making for an easier repair.
All you need to do is remove the old screen and transfer the home button to the new screen.
步骤 1 Taping the display glass  ¶
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
  • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
  • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
步骤 2 Removing the Pentalobe screws  ¶
Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
  • Power off your iPhone before beginning disassembly.
  • Remove the two 3.8 mm P2 Pentalobe screws on either side of the Lightning connector.
步骤 3 Starting the iSclack Opening Procedure  ¶
The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5c that we recommend for anyone doing more than one repair on an iPhone 5, 5s, or 5c. If you aren't using the iSclack, skip to Step 5. Close the handle on the iSclack, opening the suction-cup jaws. Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
  • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5c that we recommend for anyone doing more than one repair on an iPhone 5, 5s, or 5c. If you aren't using the iSclack, skip to Step 5.
  • Close the handle on the iSclack, opening the suction-cup jaws.
  • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
  • The top suction cup should rest just above the home button.
  • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
步骤 4 Finishing the iSclack Opening Procedure  ¶
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case. The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
  • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
  • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
  • Peel the two suction cups off your iPhone.
  • Skip the next three steps and continue on to Step 8.
步骤 5 Manual Opening Procedure  ¶
Press a suction cup onto the screen, just above the home button.
  • Press a suction cup onto the screen, just above the home button.
  • Be sure the cup is completely on the screen to get a tight seal.
步骤 6 Start lifting the front panel assembly  ¶
Make sure the suction cup is firmly attached to the front panel assembly. While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
  • Make sure the suction cup is firmly attached to the front panel assembly.
  • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
  • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
  • With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
  • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
步骤 7  ¶
Pull the plastic nub to release the vacuum seal on the suction cup.
步骤 7  ¶
  • Pull the plastic nub to release the vacuum seal on the suction cup.
  • Remove the suction cup from the display assembly.
步骤 8 Opening up the phone  ¶
Lift the home button end of the front panel up to gain access to the connectors near the top of the phone. Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
  • Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
  • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
  • In a pinch, you can use an unopened canned beverage to hold the display.
  • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
步骤 9  ¶
Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
步骤 9  ¶
  • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
步骤 10  ¶
Remove the metal battery connector bracket from the iPhone.
步骤 10  ¶
  • Remove the metal battery connector bracket from the iPhone.
步骤 11 Disconnecting the battery connector  ¶
Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
  • Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
  • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
步骤 12  ¶
Remove the following  Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
步骤 12  ¶
  • Remove the following Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
  • Two 1.3 mm screws
  • One 1.7 mm screw
  • One 3.25 mm screw
  • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 3.25 mm screw or the 1.7 mm screw in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
  • Be careful not to over-tighten the screws. If they don't fit easily when you are securing them, they may be the wrong size—don't force them.
步骤 13  ¶
Remove the front panel assembly cable bracket from the logic board.
步骤 13  ¶
  • Remove the front panel assembly cable bracket from the logic board.
步骤 14 Disconnecting the front panel assembly cables  ¶
Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector. Be sure to only pry up on the connector, and not on the socket on the logic board.
  • Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector.
  • Be sure to only pry up on the connector, and not on the socket on the logic board.
步骤 15  ¶
Make sure the battery is disconnected before you disconnect or reconnect the cables in this step. Use a plastic opening tool or a fingernail to disconnect the LCD cable connector. The LCD and Digitizer connectors are on the same cable assembly, so prying the LCD connector up should disconnect both connectors. Double check that the two cables are fully disconnected before removing the display.
步骤 15  ¶
  • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
  • Use a plastic opening tool or a fingernail to disconnect the LCD cable connector.
  • The LCD and Digitizer connectors are on the same cable assembly, so prying the LCD connector up should disconnect both connectors. Double check that the two cables are fully disconnected before removing the display.
  • When reassembling your phone, the LCD cable may pop off its connector. A blank screen, or white lines on the display could be caused by a loose connection. Should this happen, reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
步骤 16 Separating front panel assembly and rear case  ¶
Remove the front panel assembly from the rear case.
  • Remove the front panel assembly from the rear case.
