跳转到主内容
帮助
Sony Cyber-Shot DSC-W330 Circuit Board Replacement
有潜在危险
有潜在危险
如果不正确地执行这个步骤,就可能导致受伤。请保持谨慎并注意所有警告。
更好的介绍
更好的介绍
通过完成或修改其开头介绍以改善本指南。
This guide will explain the steps required to remove the main circuit board from the camera.
  • 作者: Sam Lewis
  • 估计时间: 40分钟
  • 难度: 困难
步骤 1 Circuit Board  ¶
Place the camera so that the lens would be facing down. Use the phillips head screwdriver to remove the small silver screw in the top right corner. Gently peel back the black adhesive tape from the top edge. The tape is attached to the ribbon cable. Be very careful not to tear or damage the ribbon cable when removing the tape.
  • Place the camera so that the lens would be facing down. Use the phillips head screwdriver to remove the small silver screw in the top right corner.
  • Gently peel back the black adhesive tape from the top edge.
  • The tape is attached to the ribbon cable. Be very careful not to tear or damage the ribbon cable when removing the tape.
  • Use the plastic opening tool to pry the black locking tab up.
  • Gently remove the ribbon cable from the connector
步骤 2  ¶
Grasp the circuit board with your fingers and gently pull it out of the camera. This will require you to work it back and forth because it is tightly secured to the camera. Be careful not to damage the battery terminal connectors, they may be holding the circuit board to the battery compartment.
步骤 2  ¶
  • Grasp the circuit board with your fingers and gently pull it out of the camera.
  • This will require you to work it back and forth because it is tightly secured to the camera.
  • Be careful not to damage the battery terminal connectors, they may be holding the circuit board to the battery compartment.
  • The circuit board is now removed and can be replaced if necessary.
