跳转到主内容
帮助
HP Mini 110-1046NR Keyboard Bezel Replacement
仅作为前提条件
仅作为前提条件
请注意,本指南只是其他指南的前提条件。
Prerequisite guide for replacing the hard drive, WiFi card, Fan, Motherboard, etc.
  • 作者: Jared Cooper
  • 估计时间: 30分钟
  • 难度: 中等
Prerequisite only
步骤 1 Keyboard Bezel  ¶
It is not necessary to remove the memory card for this step. Remove the 4.9mm screw located to the right of the of the memory card using a PH1 screwdriver.
  • It is not necessary to remove the memory card for this step.
  • Remove the 4.9mm screw located to the right of the of the memory card using a PH1 screwdriver.
步骤 2  ¶
Pry the four feet with the pick-end of the spudger.  These are glued down, so this may require some force. Remove the 6mm PH1 screws located under each foot. Remove the 6mm PH1 screws located under each foot.
步骤 2  ¶
  • Pry the four feet with the pick-end of the spudger. These are glued down, so this may require some force.
  • Remove the 6mm PH1 screws located under each foot.
步骤 3  ¶
Flip the netbook over and remove with a PH1 screwdriver the eight 5.9mm screws that secure the keyboard bezel in place. Only remove the black screws with "M2.5x6" markings next to them. All others are unnecessary. Taking the keyboard bezel off without removing the hard drive may be possible, but there is a risk of breaking several tabs on the keyboard bezel located between the hard drive and the frame of the computer.
步骤 3  ¶
  • Flip the netbook over and remove with a PH1 screwdriver the eight 5.9mm screws that secure the keyboard bezel in place.
  • Only remove the black screws with "M2.5x6" markings next to them. All others are unnecessary.
  • Taking the keyboard bezel off without removing the hard drive may be possible, but there is a risk of breaking several tabs on the keyboard bezel located between the hard drive and the frame of the computer.
  • Using the flat end of the spudger or pry stick, pry the keyboard bezel away from the base by wedging the tool between the base and keyboard bezel and run the tool along the side until the cover is fully released.
  • Don't pull the front of the keyboard up very far. There is a small, potentially fragile ribbon cable on the back of the touchpad that is still attached to the system board.
  • Carefully flip the keyboard bezel over (toward you) to reveal the touchpad ribbon cable.
步骤 4  ¶
Locate the black and white tab that connects the touchpad ribbon cable to the motherboard. Using your fingernail or a pry stick, flip the white tab up to release the ribbon cable end. Remove the touchpad ribbon cable from the receptacle on the system board by gently pulling the ribbon away from the clamp.
步骤 4  ¶
  • Locate the black and white tab that connects the touchpad ribbon cable to the motherboard.
  • Using your fingernail or a pry stick, flip the white tab up to release the ribbon cable end.
  • Remove the touchpad ribbon cable from the receptacle on the system board by gently pulling the ribbon away from the clamp.
