跳转到主内容
帮助
Sidekick II Outer Casing Replacement
Taking apart the outside casing.
步骤 1 Outer Casing  ¶
Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
步骤 1 Outer Casing  ¶
  • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
  • Gently pry open button and remove button.
  • Do this for each of the 3 buttons remaining.
步骤 2  ¶
The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
步骤 2  ¶
  • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
步骤 3  ¶
Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
步骤 3  ¶
  • Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
步骤 4  ¶
Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
步骤 4  ¶
  • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
  • Use the Torx 6 screwdriver to remove these 2 screws.
  • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
步骤 5  ¶
After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
步骤 5  ¶
  • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
  • You can use your hands to simply pull apart the top casing from the bottom casing.
