跳转到主内容
帮助
iMac Intel 21.5" EMC 2308 Power Supply Replacement
有潜在危险
有潜在危险
如果不正确地执行这个步骤,就可能导致受伤。请保持谨慎并注意所有警告。
Use this guide to replace a faulty power supply.
步骤 1 Power Supply  ¶
Remove the following four screws securing the power supply to the outer case:
步骤 1 Power Supply  ¶
  • Remove the following four screws securing the power supply to the outer case:
  • Two 22.2 mm fine-thread T10 Torx
  • One 25 mm coarse-thread T10 Torx
  • One 9 mm coarse-thread T10 Torx
  • The next few steps bring your hands close to the exposed face of the power supply. To avoid a high voltage shock from the many large capacitors attached to the board, do not touch the face of the power supply.
步骤 2  ¶
Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out cable still attaching it to the iMac.
步骤 2  ¶
  • Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out cable still attaching it to the iMac.
  • Disconnect the DC-In cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
  • Once the locking mechanism has cleared the socket, pull the DC-In connector away from the power supply.
步骤 3  ¶
Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
步骤 3  ¶
  • Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
  • Remove the power supply from the outer case.
