跳转到主内容
帮助
Samsung Galaxy S4 Rear Facing Camera Replacement
Replace the rear-facing camera on a Samsung Galaxy S4.
Use this guide to replace the rear-facing camera in your Samsung Galaxy S4.
If you are getting a "Camera failed" error message, first open Camera app from the Application manager and select "Clear data," then restart the phone. If this doesn't solve the issue, try a factory reset of the phone (be sure to back up your data beforehand). If these options still don't help, try reinstalling Android OS, otherwise you will need to replace the hardware itself.
You can also test the camera from the Hidden/Test menu, dial *#0*# to access the service menu.
步骤 1 Rear Facing Camera  ¶
Use the flat end of a spudger to disconnect the rear-facing camera connector.
  • Use the flat end of a spudger to disconnect the rear-facing camera connector.
步骤 2  ¶
Using tweezers, or your fingers, slide the rear-facing camera out of its notch in the motherboard. Using tweezers, or your fingers, slide the rear-facing camera out of its notch in the motherboard.
步骤 2  ¶
  • Using tweezers, or your fingers, slide the rear-facing camera out of its notch in the motherboard.
