跳转到主内容
帮助
BlackBerry 8700c Replacing Logic Board Replacement
缺少前提条件
缺少前提条件
本指南缺少关于如何开始这些步骤的信息。请编写前提指南!
  • 作者: arlebrun
  • 估计时间: 15分钟
  • 难度: 简单
This Repair guide will walk you through the steps on how to replace a RIM Blackberry 8700c logic board.
步骤 1 Replacing Logic Board  ¶
Remove the back cover by pushing down on the button and sliding the cover towards the bottom of the phone. Set the cover aside.  The battery will now be exposed.
  • Remove the back cover by pushing down on the button and sliding the cover towards the bottom of the phone.
  • Set the cover aside. The battery will now be exposed.
步骤 2  ¶
Remove the battery by pulling back on the notch on top edge of the battery. Set the battery aside.
步骤 2  ¶
  • Remove the battery by pulling back on the notch on top edge of the battery.
  • Set the battery aside.
步骤 3  ¶
Unscrew and remove all four T6 Torx screws.
步骤 3  ¶
  • Unscrew and remove all four T6 Torx screws.
步骤 4  ¶
Pull the back cover of the phone off and set it aside. Pull the back cover of the phone off and set it aside.
步骤 4  ¶
  • Pull the back cover of the phone off and set it aside.
步骤 5  ¶
Unscrew and remove all 4 T6 Torx screws. Unscrew and remove all 4 T6 Torx screws.
步骤 5  ¶
  • Unscrew and remove all 4 T6 Torx screws.
步骤 6  ¶
Lift and remove inner back cover and set aside. A small side piece may fall away but is simple to reattach. Remove logic board by gently lifting it off of the front cover of the phone.
步骤 6  ¶
  • Lift and remove inner back cover and set aside.
  • A small side piece may fall away but is simple to reattach.
  • Remove logic board by gently lifting it off of the front cover of the phone.
  • New logic board can now simply be set in place.
