跳转到主内容
帮助
LG VX5600 Battery Replacement
更好的介绍
更好的介绍
通过完成或修改其开头介绍以改善本指南。
This guide will show you how to install a new battery into your LG VX5600 phone.
  • 作者: Irena Tran
  • 估计时间: 5分钟
  • 难度: 简单
This guide requires very little disassembly to complete.
步骤 1 Battery  ¶
Hold your phone with the back casing facing you and the bottom of the phone towards the sky. Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
步骤 1 Battery  ¶
  • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
  • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
步骤 2  ¶
Insert your finger into the small indentation above the battery. Push down on the battery and pull it away from the phone; it will pop out.
步骤 2  ¶
  • Insert your finger into the small indentation above the battery.
  • Push down on the battery and pull it away from the phone; it will pop out.
