跳转到主内容
帮助
MacBook Air 13" Mid 2013 Battery Replacement
Replace the Battery in your MacBook Air 13" Mid 2013.
  • 作者: Walter Galan
  • 估计时间: 15分钟
  • 难度: 中等
Use this guide to replace the battery.
Note: If there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
步骤 1 Battery  ¶
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
步骤 1 Battery  ¶
  • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
  • Do not lift upward on the connector as you disconnect it.
步骤 2  ¶
Remove the following five screws securing the battery to the upper case:
步骤 2  ¶
  • Remove the following five screws securing the battery to the upper case:
  • Three 6.3 mm T5 Torx screws
  • Two 2.4 mm T5 Torx screws
步骤 3  ¶
When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
步骤 3  ¶
  • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
  • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  • If you're installing a new battery, you should calibrate it after installation:
  • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
  • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
