跳转到主内容
帮助
Toshiba Satellite A215 S4697 RAM Replacement
特色学生指南
特色学生指南
该指南是我们优秀学生的辛勤劳动的成果,iFixit的工作人员认为这个很酷。
要点符号!
要点符号!
更好地协调标记与要点符号的颜色和类型将有助于使本指南更清楚!
A quick guide on installing extra RAM on to your Toshiba Satellite A215 S4697
Installing the RAM is a quick and easy process, just make sure you have the appropriate RAM for your laptop. The Toshiba Satellite A215 S4697 has a max of 4GB of RAM. This means two 2GB of RAM cards.
步骤 1 RAM  ¶
Close the laptop and turn it over so that the base is facing upwards and the spine is away from you. Unscrew the two captive screws with the Phillips #1 and open the compartment. Note that these captive screws cannot be removed from the lid.
步骤 1 RAM  ¶
  • Close the laptop and turn it over so that the base is facing upwards and the spine is away from you.
  • Unscrew the two captive screws with the Phillips #1 and open the compartment.
  • Note that these captive screws cannot be removed from the lid.
步骤 2  ¶
Pull the two tabs away from the RAM so that the RAM will pop out. Gently pull the RAM away from base. Gently pull the RAM away from base.
步骤 2  ¶
  • Pull the two tabs away from the RAM so that the RAM will pop out.
  • Gently pull the RAM away from base.
步骤 3  ¶
Insert new RAM chips here. Be sure that you are putting it in the right way by comparing the gold connectors to the shape of the slot. Insert new RAM chips here. Be sure that you are putting it in the right way by comparing the gold connectors to the shape of the slot.
步骤 3  ¶
  • Insert new RAM chips here. Be sure that you are putting it in the right way by comparing the gold connectors to the shape of the slot.
