跳转到主内容
帮助
iHome iD95 Button Cover Replacement
令人困惑的文字
令人困惑的文字
本指南的一些文字是混乱的,重复的,或偏离主题。请通过编辑使其明确!
This guide will help you replace the plastic button covers on the top of your iHome.
  • 作者: Vincent Chan
  • 估计时间: 55分钟 - 1小时
  • 难度: 中等
Install a new plastic button cover if yours is cracked or broken.
步骤 1 Button Cover  ¶
Flip the logic board over. Use a plastic opening tool to pry and lift the iPod adapter zip connector from the logic board.
步骤 1 Button Cover  ¶
  • Flip the logic board over.
  • Use a plastic opening tool to pry and lift the iPod adapter zip connector from the logic board.
步骤 2  ¶
Use a plastic opening tool to pry and lift up the white zip connector attaching the LCD screen to the buttons. Use a plastic opening tool to pry and lift up the white zip connector attaching the LCD screen to the buttons.
步骤 2  ¶
  • Use a plastic opening tool to pry and lift up the white zip connector attaching the LCD screen to the buttons.
步骤 3  ¶
Gently push the screen away from you to dislodge it from the plastic clip holding it in place and then pull up to remove. Gently push the screen away from you to dislodge it from the plastic clip holding it in place and then pull up to remove.
步骤 3  ¶
  • Gently push the screen away from you to dislodge it from the plastic clip holding it in place and then pull up to remove.
步骤 4  ¶
Use a Phillips #000 screwdriver to unscrew six, 5 mm-length 5 mm-head, screws attaching the buttons to the case. Use a Phillips #000 screwdriver to unscrew six, 5 mm-length 5 mm-head, screws attaching the buttons to the case.
步骤 4  ¶
  • Use a Phillips #000 screwdriver to unscrew six, 5 mm-length 5 mm-head, screws attaching the buttons to the case.
步骤 5  ¶
Behind the green board is the plastic button cover. Slowly lift it off with your hands. Behind the green board is the plastic button cover. Slowly lift it off with your hands.
步骤 5  ¶
  • Behind the green board is the plastic button cover. Slowly lift it off with your hands.
