跳转到主内容
帮助
iBook G3 14" Airport Card Replacement
  • 作者: iRobot
  • 难度: 简单
Install an original Airport 802.11b card internally.
步骤 1 Airport Card  ¶
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
步骤 1 Airport Card  ¶
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
步骤 2  ¶
If your computer does not have an Airport card installed, skip to the RAM shield removal step.
步骤 2  ¶
  • If your computer does not have an Airport card installed, skip to the RAM shield removal step.
  • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
步骤 3  ¶
Grasp the clear plastic tab on the Airport card and pull toward the right.
步骤 3  ¶
  • Grasp the clear plastic tab on the Airport card and pull toward the right.
步骤 4  ¶
Hold the Airport card in one hand and use your other hand to remove the antenna cable.
步骤 4  ¶
  • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
