跳转到主内容
帮助
Ibanez 5 String Bass Model SR405QM Output Jack Replacement
需要更好的图片
需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片​​!
标记错误
标记错误
本指南需要更好的标记。请帮助纠正或制作一些标记批注。
令人困惑的文字
令人困惑的文字
本指南的一些文字是混乱的,重复的,或偏离主题。请通过编辑使其明确!
Replacing the output jack.
In this guide you will learn how to replace the output jack. Output jack replacement will need to be done if your bass no longer makes sound, the bass only makes sound when the cable is orientated awkwardly or the bass cuts in and out when the cable is moved. Your output jack can break because the delicate metal parts which make contact with the instrument cable have been worn out or bent out of shape. Sadly this Ibanez series bass uses a closed output jack, thus it is impossible to fix, and can only be replaced.
步骤 1 Output Jack  ¶
Lift the green printed circuit board to move some of the wires Locate the output jack at the base of the cavity. Move wires away from the end of the output jack to expose the three pins.
步骤 1 Output Jack  ¶
  • Lift the green printed circuit board to move some of the wires
  • Locate the output jack at the base of the cavity.
  • Move wires away from the end of the output jack to expose the three pins.
步骤 2  ¶
Locate the gold nut at the base of the output Jack. Do not remove the nut completely, but leave it about halfway down the output jack. We only want to move the prongs slightly away from all of the wires to allow for easier soldering.
步骤 2  ¶
  • Locate the gold nut at the base of the output Jack.
  • Do not remove the nut completely, but leave it about halfway down the output jack. We only want to move the prongs slightly away from all of the wires to allow for easier soldering.
  • Use the wrench to loosen the nut.
步骤 3  ¶
Use a soldering iron to remove the three wires (two black, one white) from the output jack. The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand. The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
步骤 3  ¶
  • Use a soldering iron to remove the three wires (two black, one white) from the output jack.
  • The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
步骤 4  ¶
Remove the loosened nut completely by rotating it counter-clockwise. Remove the loosened nut completely by rotating it counter-clockwise. Remove the loosened nut completely by rotating it counter-clockwise.
步骤 4  ¶
  • Remove the loosened nut completely by rotating it counter-clockwise.
步骤 5  ¶
Flip the bass over. Remove output jack by pushing it gently from the back of the instrument and pulling it out from the front. Insert a new output jack and tighten the nut about halfway.
步骤 5  ¶
  • Flip the bass over.
  • Remove output jack by pushing it gently from the back of the instrument and pulling it out from the front.
  • Insert a new output jack and tighten the nut about halfway.
步骤 6  ¶
Use the soldering iron to attach the wires on to the new output jack according to the wiring diagram.
步骤 6  ¶
  • Use the soldering iron to attach the wires on to the new output jack according to the wiring diagram.
  • Securely tighten the nut using the adjustable wrench.
