跳转到主内容
帮助
iPad Mini CDMA Front Panel Assembly Replacement
仅作为前提条件
仅作为前提条件
请注意,本指南只是其他指南的前提条件。
Replace the Front Panel Assembly in your iPad Mini CDMA.
Use this guide to replace the front panel assembly.
步骤 1 Front Panel Assembly  ¶
Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work. To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
  • Be very careful to pry evenly on the digitizer connector, and not on the socket at all. The socket and connector are very delicate and if you damage either, your digitizer won't work.
  • To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
  • Gently pry the digitizer connector up from its socket on the logic board.
步骤 2  ¶
Gently pry the digitizer cable board up from the rear case. Gently pry the digitizer cable board up from the rear case.
步骤 2  ¶
  • Gently pry the digitizer cable board up from the rear case.
步骤 3  ¶
Lift and remove the front panel from the iPad. Lift and remove the front panel from the iPad.
步骤 3  ¶
  • Lift and remove the front panel from the iPad.
