跳转到主内容
帮助
Hover-1 Horizon Left Balancing Sensor Replacement
Replace the left balancing sensors on the Hover-1 Horizon.
  • 作者: Jesus
  • 估计时间: 40 - 45 分钟
  • 难度: 中等
Is your hoverboard unbalanced or leaning to one side while riding? This is a guide to show you how to remove the left balance sensor tab on the Hover-1 Horizon, the most likely culprit to your problem. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
步骤 1 Left Balancing Sensors  ¶
Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard. The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten. The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
  • Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
  • The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
步骤 2  ¶
Remove the sensor tab by carefully lifting it away from the hoverboard. Remove the sensor tab by carefully lifting it away from the hoverboard.
步骤 2  ¶
  • Remove the sensor tab by carefully lifting it away from the hoverboard.
