跳转到主内容
帮助
Disassembling Sony Ericsson w600i LCD Section
更好的介绍
更好的介绍
通过完成或修改其开头介绍以改善本指南。
Disassembling the LCD section allows access to the LCD Buttons and LCD Screen.
步骤 1 LCD Section  ¶
Remove the four black Phillips screws holding the swivel assembly to the LCD section of the phone. Be mindful of the screws, as they are very small.
步骤 1 LCD Section  ¶
  • Remove the four black Phillips screws holding the swivel assembly to the LCD section of the phone.
  • Be mindful of the screws, as they are very small.
  • The screws are Phillips, 2.4mm
步骤 2  ¶
Gently remove the grey plastic cover at the top-rear of the LCD section with a spudger.
步骤 2  ¶
  • Gently remove the grey plastic cover at the top-rear of the LCD section with a spudger.
  • It is secured with adhesive tape, the more gently you remove this piece, the easier reassembly will be later.
步骤 3  ¶
Remove the two Torx screws revealed under the grey cover.
步骤 3  ¶
  • Remove the two Torx screws revealed under the grey cover.
  • The screws are Torx T5, 5.6mm
步骤 4  ¶
Gently pry off the front face, starting at the bottom slot.
步骤 4  ¶
  • Gently pry off the front face, starting at the bottom slot.
步骤 5  ¶
Remove the Torx screws near the buttons.
步骤 5  ¶
  • Remove the Torx screws near the buttons.
步骤 6  ¶
Remove the black front plate. Remove the button overlay, taking note of its position for reassembly. There are small grey nubs that correspond to holes in the overlay.
步骤 6  ¶
  • Remove the black front plate.
  • Remove the button overlay, taking note of its position for reassembly. There are small grey nubs that correspond to holes in the overlay.
步骤 7  ¶
Gently release the small grey retaining clips around the outside of the display assembly.
步骤 7  ¶
  • Gently release the small grey retaining clips around the outside of the display assembly.
  • Separate the display assembly from its backplate.
  • Take care; some of the side buttons may dislodge as the backplate is separated.
  • The LCD section is now disassembled.
