跳转到主内容
帮助
iPod Touch 2nd Generation Display Replacement
特色指南
特色指南
iFixit的工作人员认为该指南特别酷。
Replace a broken display with this guide.
步骤 1 Display  ¶
Insert a small iPod opening tool with the edge angled up toward the underside of the display between the white plastic backlight and the metal shield beneath it. Pry up along the lower edge of the display enough to grab it with your fingers.
步骤 1 Display  ¶
  • Insert a small iPod opening tool with the edge angled up toward the underside of the display between the white plastic backlight and the metal shield beneath it.
  • Pry up along the lower edge of the display enough to grab it with your fingers.
步骤 2  ¶
Lift the display up from its lower edge and rotate it toward the top of the Touch.
步骤 2  ¶
  • Lift the display up from its lower edge and rotate it toward the top of the Touch.
  • The next few steps require removal of components under where the display normally sits. Be sure to hold the display to avoid putting tension on the delicate display ribbon cable.
步骤 3  ¶
While holding the display with one hand, run an iPod opening tool down the two long edges of the mylar reflector attached to the metal display tray. When it is sufficiently free from the display tray, remove the mylar reflector from the Touch.
步骤 3  ¶
  • While holding the display with one hand, run an iPod opening tool down the two long edges of the mylar reflector attached to the metal display tray.
  • When it is sufficiently free from the display tray, remove the mylar reflector from the Touch.
步骤 4  ¶
Remove the seven Phillips screws securing the metal display tray to the rear panel.
步骤 4  ¶
  • Remove the seven Phillips screws securing the metal display tray to the rear panel.
  • The two darker screws belong in the two holes in the tray nearest the bottom edge of the Touch.
步骤 5  ¶
Lay the display back down into its tray.
步骤 5  ¶
  • Lay the display back down into its tray.
  • Remove the final Phillips screw securing the metal tray to the rear panel.
步骤 6  ¶
Lift the display out of the metal tray and rotate it toward the top edge of the Touch.
步骤 6  ¶
  • Lift the display out of the metal tray and rotate it toward the top edge of the Touch.
  • Use an iPod opening tool to lift the metal display tray and rotate it up toward the top edge of the Touch.
步骤 7  ¶
Use the edge of an iPod opening tool to peel the copper tape off the top edge of the display.
步骤 7  ¶
  • Use the edge of an iPod opening tool to peel the copper tape off the top edge of the display.
  • Leave the copper tape attached to the metal display tray.
步骤 8  ¶
Use an iPod opening tool to pry the display cable connector up off its socket on the logic board.
步骤 8  ¶
  • Use an iPod opening tool to pry the display cable connector up off its socket on the logic board.
步骤 9  ¶
Lift the metal display tray slightly (the battery is attached to its underside) and remove the display from the Touch, minding its delicate cable that may get caught.
步骤 9  ¶
  • Lift the metal display tray slightly (the battery is attached to its underside) and remove the display from the Touch, minding its delicate cable that may get caught.
  • The display ribbon cable is routed under the metal display tray.
