跳转到主内容
帮助
ASUS Portable AiO PT2001 Battery Replacement
How to replace the battery in an ASUS Portable AiO PT2001.
  • 作者: Runjia Chen
  • 估计时间: 15分钟
  • 难度: 简单
This guide demonstrates how to remove the battery, one of the most essential components of the device.
工具
步骤 1 Battery  ¶
Remove the eight 3.5 mm Phillips screws that secure the battery.
步骤 1 Battery  ¶
  • Remove the eight 3.5 mm Phillips screws that secure the battery.
步骤 2  ¶
Disconnect the wires by pulling on the tab. Disconnecting these wires will clear the way for removing the battery. Disconnect the wires by pulling on the tab. Disconnecting these wires will clear the way for removing the battery.
步骤 2  ¶
  • Disconnect the wires by pulling on the tab. Disconnecting these wires will clear the way for removing the battery.
步骤 3  ¶
Unplug the battery's connector from the motherboard.
步骤 3  ¶
  • Unplug the battery's connector from the motherboard.
步骤 4  ¶
Pull the battery out. Be careful not to break the cables on top.
步骤 4  ¶
  • Pull the battery out. Be careful not to break the cables on top.
