跳转到主内容
帮助
技术: Simple Fix For Stuck Power / Cancel Button
会员贡献的指南
会员贡献的指南
一位我们社区很棒的成员写出了本指南。它不是由 iFixit 工作人员管理。
Simple 30 second fix to release a stuck Power / Cancel pushbutton on the Maytag / Whirlpool Premium Front Load Washer.
  • 作者: drmdolfan
  • 估计时间: 30秒
  • 难度: 非常容易
This technique is a simple method to release a stuck Power / Cancel button on the Maytag / Whirlpool premium front load washers that have a chrome housing ring - type of button.
工具
步骤 1 Identify the Model / Safety Precaution  ¶
Identify your washer type.  The Power / Cancel button may differ with different models.  This was my model tag.
  • Identify your washer type. The Power / Cancel button may differ with different models. This was my model tag.
  • On my unit the model number tag was found by opening the washing machine door.
  • ** WARNING ** - UNPLUG POWER PRIOR TO WORKING. YOU WORK AT YOUR OWN RISK. I AM NOT RESPONSIBLE FOR YOUR SAFETY!
步骤 2 Locate the Power / Cancel Button  ¶
The power button contains  a gray colored round button actuator in a chrome housing.  The words "Power -  Cancel" (solid dot between words) are printed above the button
  • The power button contains a gray colored round button actuator in a chrome housing. The words "Power - Cancel" (solid dot between words) are printed above the button
  • Apparently the stuck button was actually caused by the chrome housing/ring being pressed in too far at the bottom or otherwise misaligned. This was not a problem with the actuator itself as I first thought.
步骤 3 Release the button housing  ¶
The simple fix here was to take a metal pick (or other thin but firm tool) and carefully get under the chrome housing (ring) at the bottom and wedge it up or slightly forward.
  • The simple fix here was to take a metal pick (or other thin but firm tool) and carefully get under the chrome housing (ring) at the bottom and wedge it up or slightly forward.
  • To my surprise there was a slight click/pop that indicated the housing ring was released.
  • Plug the washing machine back into the power source and lightly touch the Power / Cancel button actuator.
  • My advice to avoid this in the future is to more carefully "touch" the center of the gray actuator with minimal force rather then "mash" the whole button during use.
