跳转到主内容
帮助
Asus Chromebook C300SA- DS02 Battery Replacement
Removal and replacement of the keyboard from the laptop.
  • 作者: Lewis Shab
  • 估计时间: 3分钟
  • 难度: 简单
This guide will demonstrate how to safely remove the battery from your Asus Chromebook C300SA-DS02. This step by step process is simple and should take no longer then five minutes. All of the screws holding the device together are documented by the correct type during the correct step. Make sure to keep track of them throughout the guide.
步骤 1 Battery  ¶
Remove the six 5.6mm Phillips #0 screws around the battery. Remove the six 5.6mm Phillips #0 screws around the battery.
步骤 1 Battery  ¶
  • Remove the six 5.6mm Phillips #0 screws around the battery.
步骤 2  ¶
Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard. Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
步骤 2  ¶
  • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
步骤 3  ¶
Lift the battery out of the laptop.
步骤 3  ¶
  • Lift the battery out of the laptop.
