跳转到主内容
eufy RoboVac 11 Side Brush Replacement
你所需要的
  1. eufy RoboVac 11 Side Brush Replacement, Front Cover and Motherboard: 步骤 1 中的图像 1,2 eufy RoboVac 11 Side Brush Replacement, Front Cover and Motherboard: 步骤 1 中的图像 2,2
    • Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
    • Keep track of these screws. They are the same length as the interior screws but wider in diameter.
  2. eufy RoboVac 11 Side Brush Replacement: 步骤 2 中的图像 1,2 eufy RoboVac 11 Side Brush Replacement: 步骤 2 中的图像 2,2
    • Remove the six 7 mm screws on the bumper with the Phillips #1 screwdriver.
  3. eufy RoboVac 11 Side Brush Replacement: 步骤 3 中的图像 1,3 eufy RoboVac 11 Side Brush Replacement: 步骤 3 中的图像 2,3 eufy RoboVac 11 Side Brush Replacement: 步骤 3 中的图像 3,3
    • Remove the top plate from the body of the device.
    • Unplug the bumper from the motherboard.
  4. eufy RoboVac 11 Side Brush Replacement: 步骤 4 中的图像 1,2 eufy RoboVac 11 Side Brush Replacement: 步骤 4 中的图像 2,2
    • Remove the three 10 mm motherboard screws with a Phillips #1 screwdriver.
    • Cleaning the motherboard and inside of the device outdoors with a compressed air cleaner will help the robot last longer.
  5. eufy RoboVac 11 Side Brush Replacement: 步骤 5 中的图像 1,2 eufy RoboVac 11 Side Brush Replacement: 步骤 5 中的图像 2,2
    • Unplug the cables from the motherboard.
  6. eufy RoboVac 11 Side Brush Replacement, Side Brush: 步骤 6 中的图像 1,3 eufy RoboVac 11 Side Brush Replacement, Side Brush: 步骤 6 中的图像 2,3 eufy RoboVac 11 Side Brush Replacement, Side Brush: 步骤 6 中的图像 3,3
    • Remove the 10 mm side brush motor screws with the Phillips #1 screwdriver.
    • Remove the side brushes.
    • Remove the side brush motors.
结论
Myles Mattinson
于09/28/22注册
316 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 57
总计 1,860
