跳转到主内容
加入维修社区 - 创建账户
enTourage Pocket eDGe Battery Replacement
你所需要的
  1. enTourage Pocket eDGe Battery Replacement, Battery: 步骤 1 中的图像 1,3 enTourage Pocket eDGe Battery Replacement, Battery: 步骤 1 中的图像 2,3 enTourage Pocket eDGe Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe Battery Replacement: 步骤 2 中的图像 1,1
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe Battery Replacement: 步骤 3 中的图像 1,3 enTourage Pocket eDGe Battery Replacement: 步骤 3 中的图像 2,3 enTourage Pocket eDGe Battery Replacement: 步骤 3 中的图像 3,3
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe Battery Replacement: 步骤 4 中的图像 1,1
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe Battery Replacement: 步骤 5 中的图像 1,1
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
结论
3等其他人完成本指南。
Adrian Do
于09/24/15注册
355 声望
创作了3篇指南
2指南评论
Great tutorial! I have two of these. Does anyone know where I can buy a replacement battery? I have looked everywhere. I would retrofit if I could find one large and flat enough. 7.2v 2000mA. Hate to have to trash them but they don’t make parts anymore.
Ron - 回复
does anyone know the pin out of the battery connector, thank you
Tony - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 41
总计 1,773
