跳转到主内容
eMac RAM Door Replacement
你所需要的
  1. eMac RAM Door Replacement, Door Removal: 步骤 1 中的图像 1,3 eMac RAM Door Replacement, Door Removal: 步骤 1 中的图像 2,3 eMac RAM Door Replacement, Door Removal: 步骤 1 中的图像 3,3
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
结论
4等其他人完成本指南。
Chris Green
于10/11/09注册
38,113 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
329 名成员
创作了1,452篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,037
