跳转到主内容
加入维修社区 - 创建账户
eMac Optical Drive Removal
你所需要的
  1. eMac Optical Drive Removal, Door Removal: 步骤 1 中的图像 1,3 eMac Optical Drive Removal, Door Removal: 步骤 1 中的图像 2,3 eMac Optical Drive Removal, Door Removal: 步骤 1 中的图像 3,3
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
  2. eMac Optical Drive Removal, Bottom Screw Removal: 步骤 2 中的图像 1,1
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
  3. eMac Optical Drive Removal, Top and Side Screws: 步骤 3 中的图像 1,3 eMac Optical Drive Removal, Top and Side Screws: 步骤 3 中的图像 2,3 eMac Optical Drive Removal, Top and Side Screws: 步骤 3 中的图像 3,3
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
  4. eMac Optical Drive Removal, Power Button Cable: 步骤 4 中的图像 1,2 eMac Optical Drive Removal, Power Button Cable: 步骤 4 中的图像 2,2
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
  5. eMac Optical Drive Removal, Shell Removal: 步骤 5 中的图像 1,1
    • Now the entire shell can be removed from the computer.
  6. eMac Optical Drive Removal, Panel Removal: 步骤 6 中的图像 1,3 eMac Optical Drive Removal, Panel Removal: 步骤 6 中的图像 2,3 eMac Optical Drive Removal, Panel Removal: 步骤 6 中的图像 3,3
    • The motherboard access panel is held on by 4 phillips #2 screws.
    • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
  7. eMac Optical Drive Removal, Cable Removal: 步骤 7 中的图像 1,2 eMac Optical Drive Removal, Cable Removal: 步骤 7 中的图像 2,2
    • The eMac uses a standard 5.25" IDE optical drive. Most off-the-shelf drives should work as a replacement with minor modification. The jumper setting for the drive should be "CS".
    • Start by disconnecting the IDE and power cables from the drive.
  8. eMac Optical Drive Removal, Screw Removal: 步骤 8 中的图像 1,2 eMac Optical Drive Removal, Screw Removal: 步骤 8 中的图像 2,2
    • The drive is held in by two phillips #2 screws on each side. Remove these.
  9. eMac Optical Drive Removal, Drive Removal: 步骤 9 中的图像 1,2 eMac Optical Drive Removal, Drive Removal: 步骤 9 中的图像 2,2
    • The drive should now come free.
结论
5等其他人完成本指南。
Chris Green
于10/11/09注册
38,143 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
331 名成员
创作了1,455篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 51
总计 2,956
