跳转到主内容
加入维修社区 - 创建账户
eMac Fan Assembly Replacement
你所需要的
  1. eMac Fan Assembly Replacement, Door Removal: 步骤 1 中的图像 1,3 eMac Fan Assembly Replacement, Door Removal: 步骤 1 中的图像 2,3 eMac Fan Assembly Replacement, Door Removal: 步骤 1 中的图像 3,3
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
  2. eMac Fan Assembly Replacement, Bottom Screw Removal: 步骤 2 中的图像 1,1
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
  3. eMac Fan Assembly Replacement, Top and Side Screws: 步骤 3 中的图像 1,3 eMac Fan Assembly Replacement, Top and Side Screws: 步骤 3 中的图像 2,3 eMac Fan Assembly Replacement, Top and Side Screws: 步骤 3 中的图像 3,3
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
  4. eMac Fan Assembly Replacement, Power Button Cable: 步骤 4 中的图像 1,2 eMac Fan Assembly Replacement, Power Button Cable: 步骤 4 中的图像 2,2
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
  5. eMac Fan Assembly Replacement, Shell Removal: 步骤 5 中的图像 1,1
    • Now the entire shell can be removed from the computer.
  6. eMac Fan Assembly Replacement, Panel Removal: 步骤 6 中的图像 1,3 eMac Fan Assembly Replacement, Panel Removal: 步骤 6 中的图像 2,3 eMac Fan Assembly Replacement, Panel Removal: 步骤 6 中的图像 3,3
    • The motherboard access panel is held on by 4 phillips #2 screws.
    • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
  7. eMac Fan Assembly Replacement, Cables: 步骤 7 中的图像 1,3 eMac Fan Assembly Replacement, Cables: 步骤 7 中的图像 2,3 eMac Fan Assembly Replacement, Cables: 步骤 7 中的图像 3,3
    • To remove the fan assembly, several cables must be disconnected first:
    • 3-pin fan cable
    • Ground wire, requires phillips #2 screwdriver
    • 2-pin AC cable to power supply
  8. eMac Fan Assembly Replacement, Screws: 步骤 8 中的图像 1,2 eMac Fan Assembly Replacement, Screws: 步骤 8 中的图像 2,2
    • Now remove the following screws securing the fan assembly:
    • 3x coarse thread phillips #2
    • 1x machine thread phillips #2
  9. eMac Fan Assembly Replacement: 步骤 9 中的图像 1,1
    • There may be a zip tie holding another cable to the fan assembly, cut it to remove the fan assembly.
  10. eMac Fan Assembly Replacement, Assembly Removal: 步骤 10 中的图像 1,2 eMac Fan Assembly Replacement, Assembly Removal: 步骤 10 中的图像 2,2
    • You should now be able to remove the fan assembly.
    • Doing this will expose more of the CRT neck, be careful not to touch this area because it can contain high voltages (and is fragile)
结论
3等其他人完成本指南。
Chris Green
于10/11/09注册
38,143 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
330 名成员
创作了1,452篇指南
1指南评论
Does anyone know the names of connectors for the fan? I would like to power one externally if possible.
grantdavis - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 53
总计 1,729
