跳转到主内容
加入维修社区 - 创建账户
e-lite web150 Disassembly
你所需要的
  1. e-lite web150 Disassembly, removing the blower nozzle: 步骤 1 中的图像 1,1
    • Firmly press the yellow button and slide the blower nozzle off.
  2. e-lite web150 Disassembly, un-screwing: 步骤 2 中的图像 1,1
    • un-screw all of the screws
  3. e-lite web150 Disassembly, opening: 步骤 3 中的图像 1,1
    • pull apart the 2 halves
  4. e-lite web150 Disassembly, The inside: 步骤 4 中的图像 1,1
    • This is the inside of the blower
  5. e-lite web150 Disassembly, pulling out the switch and plug: 步骤 5 中的图像 1,2 e-lite web150 Disassembly, pulling out the switch and plug: 步骤 5 中的图像 2,2
    • gently pull out the power plug and switch
  6. e-lite web150 Disassembly, removing the motor: 步骤 6 中的图像 1,2 e-lite web150 Disassembly, removing the motor: 步骤 6 中的图像 2,2
    • gently pull out the motor paying attention to which side it came out of.
  7. e-lite web150 Disassembly, putting the motor back in: 步骤 7 中的图像 1,1
    • clean the dust out if you need to. then carefully put the motor back in making sure you put both of the tabs on the motor into their respective slots. you can't see the other one because I had to crop it out.
  8. e-lite web150 Disassembly, putting the plugs back in their places: 步骤 8 中的图像 1,1
    • carefully put the plugs back into their holders.
  9. e-lite web150 Disassembly, closing it up: 步骤 9 中的图像 1,1
    • fit the 2 halves back together
  10. e-lite web150 Disassembly, screwing in the screws: 步骤 10 中的图像 1,1
    • replace all of the screws
  11. e-lite web150 Disassembly, re-attaching the blower nozzle: 步骤 11 中的图像 1,1
    • slide the blower nozzle on to the main body until it locks in place, you are done.
终点
另外一个人完成了本指南。
Alex Pollard
于11/07/16注册
119 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 532
