跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
简介
To complete this guide, you will need a PH 0 screwdriver and a spudger or similar prying device to access the interior of the Quad Dock Pro.
  1. Remove the rubber foot pads on the bottom of the device using a plastic opening tool. Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. Remove the six 2 mm PH0 screws on the bottom of the device. Four of those screws are located under the foot pads.
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. Gently remove the bottom of the device.
    • Gently remove the bottom of the device.
结论
另外一个人完成了本指南。
Jacob
于2015年03月11日注册
750 信誉积分
创作了6篇指南
团队
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 62
