跳转到主内容
dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement
你所需要的
  1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: 步骤 1 中的图像 1,2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: 步骤 1 中的图像 2,2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 步骤 2 中的图像 1,2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 步骤 2 中的图像 2,2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 步骤 3 中的图像 1,1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: 步骤 4 中的图像 1,2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: 步骤 4 中的图像 2,2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 步骤 5 中的图像 1,1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 步骤 6 中的图像 1,2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: 步骤 7 中的图像 1,2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: 步骤 7 中的图像 2,2
    • Remove the four 1.8 mm PH0 screws that are holding the board in.
    • When you remove these screws, the plastic cups inside the PS Move stations will fall out.
  8. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 步骤 8 中的图像 1,1
    • Pick up the board.
    • Pick the board straight up, or you risk damaging the charging ports.
  9. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: 步骤 9 中的图像 1,1
    • Using a plastic opening tool or a similar tool, gently pry the power ribbon cord out of its port.
结论
另外一个人完成了本指南。
Jacob
于03/11/15注册
757 声望
创作了6篇指南
团队
Colorado Springs, Team 4-4, Panko Spring 2015 Colorado Springs, Team 4-4, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 221
