简介
"dead" ac adapter maybe revived again
often just the internal thermal fuse is blown
open the housing, solder a new thermal fuse (or just a "bridge" -if no fuse at hand for the moment...), close the housing... done!
remarks:
the original thermal fuse is situated IN the primary circuit where in case of over-current the heat-development is maximal, thus it switches well-
our (possible) replacement is AT the primary circuit (at best!) and wont get the same heat, while IN the circuit the heat-development may be (already) higher so the use of a thermal fuse with a lower rating (85 degrees) is recommended -with the clear disadvantage that it could switch off TOO early, in normal use but eg under higher ambient-temps or bad venting.. could mean you have to replace it again... -possibly the rating of the substitute can thus be higher.... that depends on your specific situation and use -find out-
me, i even leaved the thermal fuse and just soldered a "brigde"... but in case of emergency this could even lead to a burning device!!! so i wont recommend this to the public
p.s. the reason why my ac-adapter initially blew up:
had attached it to a wrong device that awaited DC-current -with a protection diode towards ground in the input- that resulted in short-circuit-current-drain in one half-wave... became quit hot and ...dead...
Warning: Using this guide may expose you to voltage. Exercise extreme caution when following this guide.
你所需要的
solder the new thermal fuse (or bridge) between the left and the middle contact (in the picture there is just a bridge -above the red tape-... (had no thermal fuse at hand at first...)
found one 85c in a used li-ion-pack... be VERY careful when soldering NOT to exceed the max. temp meanwhile--- suggest to put a final layer of tape around to get better contact to the coil -where the heat is coming from in case of overload-
close the lid and add eg thermo-glue or just use the soldering-iron and make the housing melt along the pits
8等其他人完成本指南。
how to open the housing
sard_chalakur - 回复
