跳转到主内容
creative ac adapter model maf115160th
你所需要的
  1. creative ac adapter model maf115160th, panel: 步骤 1 中的图像 1,2 creative ac adapter model maf115160th, panel: 步骤 1 中的图像 2,2
    • panel view
  2. creative ac adapter model maf115160th, inside view: 步骤 2 中的图像 1,1
    • solder the new thermal fuse (or bridge) between the left and the middle contact (in the picture there is just a bridge -above the red tape-... (had no thermal fuse at hand at first...)
  3. creative ac adapter model maf115160th: 步骤 3 中的图像 1,1
    • found one 85c in a used li-ion-pack... be VERY careful when soldering NOT to exceed the max. temp meanwhile--- suggest to put a final layer of tape around to get better contact to the coil -where the heat is coming from in case of overload-
结论
close the lid and add eg thermo-glue or just use the soldering-iron and make the housing melt along the pits
8等其他人完成本指南。
biopilz
于03/08/17注册
465 声望
创作了2篇指南
3指南评论
My A300 speaker adapters has blown I need to get a new one
Sakhile Lloyd - 回复
Can you show me of this Adapter diagram. The middle line in primary is broken but i don’t know how to connect to which leg
Tien - 回复
Can I use the lead line instead of fuse to connected
Tien - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 26
过去 30 天: 109
总计 9,279
