跳转到主内容
bObsweep Robotic Vacuum Battery Replacement
你所需要的
视频概述
  1. bObsweep Robotic Vacuum Battery Replacement, Battery: 步骤 1 中的图像 1,3 bObsweep Robotic Vacuum Battery Replacement, Battery: 步骤 1 中的图像 2,3 bObsweep Robotic Vacuum Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Unscrew the battery's cover plate on bObsweep's underside, above the main brush.
    • Lift the cover plate to expose the battery.
  2. bObsweep Robotic Vacuum Battery Replacement: 步骤 2 中的图像 1,3 bObsweep Robotic Vacuum Battery Replacement: 步骤 2 中的图像 2,3 bObsweep Robotic Vacuum Battery Replacement: 步骤 2 中的图像 3,3
    • Lift the battery up and out of its compartment.
    • Using both hands, pinch the plastic connector where the battery's wiring attaches to bObsweep and pull apart to disconnect.
  3. bObsweep Robotic Vacuum Battery Replacement: 步骤 3 中的图像 1,3 bObsweep Robotic Vacuum Battery Replacement: 步骤 3 中的图像 2,3 bObsweep Robotic Vacuum Battery Replacement: 步骤 3 中的图像 3,3
    • Connect the wires of the new battery. Push together tightly and it will lock in place.
    • Tuck the wires down inside the battery compartment on the right side.
    • Lower the battery down into bObsweep with the barcode facing up.
  4. bObsweep Robotic Vacuum Battery Replacement: 步骤 4 中的图像 1,3 bObsweep Robotic Vacuum Battery Replacement: 步骤 4 中的图像 2,3 bObsweep Robotic Vacuum Battery Replacement: 步骤 4 中的图像 3,3
    • Lower the cover down so it lies flat and the screw holes of the cover line up with those on bObsweep.
    • Reinstall the two screws removed in step one to secure the cover and battery in place.
结论
A quick fix for bObsweep's power supply. Changing an old lithium ion battery for a new one ensures the vacuum will work longer with fewer charging breaks.
另外一个人完成了本指南。
Tatiana
于06/28/14注册
737 声望
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 2,810
