跳转到主内容
加入维修社区 - 创建账户
bObi Pet Front Wheel Disassembly
你所需要的
  1. bObi Pet Front Wheel Disassembly, Turn bObi Pet Off: 步骤 1 中的图像 1,3 bObi Pet Front Wheel Disassembly, Turn bObi Pet Off: 步骤 1 中的图像 2,3 bObi Pet Front Wheel Disassembly, Turn bObi Pet Off: 步骤 1 中的图像 3,3
    • To start, turn bObi Pet's side power switch to OFF and flip her over so the wheels point up.
    • Remove bObi Pet’s front wheel. Grip it with your hand and pull up, using a screwdriver for leverage.
  2. bObi Pet Front Wheel Disassembly, Remove the Front Wheel: 步骤 2 中的图像 1,3 bObi Pet Front Wheel Disassembly, Remove the Front Wheel: 步骤 2 中的图像 2,3 bObi Pet Front Wheel Disassembly, Remove the Front Wheel: 步骤 2 中的图像 3,3
    • You may remove and clean the smaller wheel on bObi Pet’s wheel piece.
    • To detach it, grip firmly and pull. Once again, you may use the screwdriver for this step.
  3. bObi Pet Front Wheel Disassembly, Open the Wheel: 步骤 3 中的图像 1,3 bObi Pet Front Wheel Disassembly, Open the Wheel: 步骤 3 中的图像 2,3 bObi Pet Front Wheel Disassembly, Open the Wheel: 步骤 3 中的图像 3,3
    • Flip the wheel over and remove the 2 screws holding the wheel piece together.
    • Remember to keep these screws for reassembly.
    • Then pop the outer casing open and you'll be able to clean the front wheel's interior with bObi Pet's cleaning tool or compressed air.
  4. bObi Pet Front Wheel Disassembly, Clean the Wheel's Interior: 步骤 4 中的图像 1,2 bObi Pet Front Wheel Disassembly, Clean the Wheel's Interior: 步骤 4 中的图像 2,2
    • After cleaning the inside of the wheel piece, replace the spring inside.
    • Then, align the edges of its outer casing.
  5. bObi Pet Front Wheel Disassembly, Put the Wheel Back Together: 步骤 5 中的图像 1,3 bObi Pet Front Wheel Disassembly, Put the Wheel Back Together: 步骤 5 中的图像 2,3 bObi Pet Front Wheel Disassembly, Put the Wheel Back Together: 步骤 5 中的图像 3,3
    • Hold the wheel piece together while you reinstall the 2 screws.
    • You may replace the small wheel on the other side of the front wheel piece, opposite to the screws.
  6. bObi Pet Front Wheel Disassembly, Replace the Wheel on bObi Pet: 步骤 6 中的图像 1,3 bObi Pet Front Wheel Disassembly, Replace the Wheel on bObi Pet: 步骤 6 中的图像 2,3 bObi Pet Front Wheel Disassembly, Replace the Wheel on bObi Pet: 步骤 6 中的图像 3,3
    • Lastly, place the front wheel back in its space on bObi Pet.
    • Push down firmly to lock the wheel in place.
结论
Congratulations on completing bObi Pet's front wheel disassembly!
Chelsea
于09/24/14注册
2,278 声望
创作了31篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 282
