简介
Guide for the removal and replacement of the communications board on the Zune Flash media player.
你所需要的
Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
If the device turns on while it is being disassembled it could cause irreversible damage to the device.
Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver.
3等其他人完成本指南。
