跳转到主内容
Zune Flash 2nd Generation Back Cover Replacement
你所需要的
  1. Zune Flash 2nd Generation Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Zune Flash 2nd Generation Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Zune Flash 2nd Generation Back Cover Replacement: 步骤 2 中的图像 1,2 Zune Flash 2nd Generation Back Cover Replacement: 步骤 2 中的图像 2,2
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. Zune Flash 2nd Generation Back Cover Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
  4. Zune Flash 2nd Generation Back Cover Replacement: 步骤 4 中的图像 1,3 Zune Flash 2nd Generation Back Cover Replacement: 步骤 4 中的图像 2,3 Zune Flash 2nd Generation Back Cover Replacement: 步骤 4 中的图像 3,3
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  5. Zune Flash 2nd Generation Back Cover Replacement: 步骤 5 中的图像 1,3 Zune Flash 2nd Generation Back Cover Replacement: 步骤 5 中的图像 2,3 Zune Flash 2nd Generation Back Cover Replacement: 步骤 5 中的图像 3,3
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
结论
ybahman
于11/01/09注册
139 声望
创作了4篇指南
团队
Cal Poly, Team 9-20, Regan Fall 2009 Cal Poly, Team 9-20, Regan Fall 2009 的会员
CPSU-REGAN-F09S9G20
5 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 20
总计 3,936
