跳转到主内容
Zte Avail 2 Display Replacement
你所需要的
  1. Zte Avail 2 Display Replacement, Battery: 步骤 1 中的图像 1,3 Zte Avail 2 Display Replacement, Battery: 步骤 1 中的图像 2,3 Zte Avail 2 Display Replacement, Battery: 步骤 1 中的图像 3,3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. Zte Avail 2 Display Replacement: 步骤 2 中的图像 1,2 Zte Avail 2 Display Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by the notch in the back plate.
  3. Zte Avail 2 Display Replacement, Display: 步骤 3 中的图像 1,1
    • Using your J00 screwdriver, unscrew each of the 8 Philips head 1.19mm screws from the black plate of the device.
  4. Zte Avail 2 Display Replacement: 步骤 4 中的图像 1,2 Zte Avail 2 Display Replacement: 步骤 4 中的图像 2,2
    • Using a spudger or plastic opening tool, pull up from underneath the back plate and pop off the piece.
  5. Zte Avail 2 Display Replacement: 步骤 5 中的图像 1,2 Zte Avail 2 Display Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. Zte Avail 2 Display Replacement: 步骤 6 中的图像 1,1
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. Zte Avail 2 Display Replacement: 步骤 7 中的图像 1,1
    • Lift and set aside the motherboard from lying on top of the silver plate (this may require some force because it is held on by adhesive).
  8. Zte Avail 2 Display Replacement: 步骤 8 中的图像 1,1
    • Using an opening tool, lift and remove the silver metal plate off the back of the device (use some force here).
  9. Zte Avail 2 Display Replacement: 步骤 9 中的图像 1,1
    • Pry open to separate the metal piece from the front screen attachment using a plastic spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
结论
5等其他人完成本指南。
dunnluke
于09/22/15注册
237 声望
撰写一个指南
一条评论
My screen is completely white and I DON'T have to turn the power off, jus the screen off n on n still screen is white. I can't hardly see my apps. Plz tell me what's wrong with my phone. I was thinking somewhere along the lines of my LED cuz everything looks kind of like a negative photo.
Joyce - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 968
