简介
In this guide, we will take you through a step-by-step approach on how to replace a broken graphics card fan specifically the Zotac GTX 1080 Ti Mini. A couple of reasons why you might need to do the replacement is the graphics card fans can stop functioning efficiently, become noisy, or completely stop working. In order to fix these problems, you can use the guide to help.
你所需要的
Use a Phillips #0 screwdriver to remove the two 4mm screws from the right side of the shroud.
Remove the three 3 mm Phillips screws holding the fans to the heatsink with a Phillips #0 screwdriver.
Remove the broken fans.
Do you have the specifications for the screws? One of my screws went missing and based on the others, its around 1-1.6mm wide for the screw itself (dont have toos to measure exact), 3mm long (as stated), and aroud 5mm wide for the head. Hoping I can get that missing dimensions before I go and purchase.
Hopefully, your graphics card is fully replaced and completely working now.
另外一个人完成了本指南。
