跳转到主内容
Zotac GTX 1080 Ti Mini Fans Replacement
你所需要的
  1. Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: 步骤 1 中的图像 1,2 Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: 步骤 1 中的图像 2,2
    • Be sure to properly ground yourself with an anti-static wristband before working on the graphics card.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the right side of the shroud.
  2. Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 2 中的图像 1,2 Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the left side of the shroud.
  3. Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 3 中的图像 1,2 Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 3 中的图像 2,2
    • Look for the fan header located beside the 16-pin power connector.
    • Gently pry the fan connector apart from the header with a flathead screwdriver.
  4. Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 4 中的图像 1,2 Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 4 中的图像 2,2
    • Slowly and carefully lift the shroud off the heatsink.
    • During this step, make sure not to damage the LED connector that is still connecting the shroud to the PCB.
    • Flip the shroud along the top of the graphics card.
  5. Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 5 中的图像 1,3 Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 5 中的图像 2,3 Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 5 中的图像 3,3
    • Remove the three 3 mm Phillips screws holding the fans to the heatsink with a Phillips #0 screwdriver.
    • Remove the broken fans.
  6. Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 6 中的图像 1,3 Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 6 中的图像 2,3 Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 6 中的图像 3,3
    • Place the replacement fan on top of the heatsink with the screw holes aligned.
    • Screw the fans into place using a Phillips #0 screwdriver.
  7. Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 7 中的图像 1,1
    • Reconnect the fan connector to its header.
  8. Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 8 中的图像 1,3 Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 8 中的图像 2,3 Zotac GTX 1080 Ti Mini Fans Replacement: 步骤 8 中的图像 3,3
    • Place the shroud back over the heatsink and screw it back into place using a Phillips #0 screwdriver.
结论
Hopefully, your graphics card is fully replaced and completely working now.
另外一个人完成了本指南。
Victor Pan
于01/27/21注册
175 声望
撰写一个指南
团队
一条评论
Do you know what size (diameter and thread) the 4mm and 3mm screws are?
cchagadorn - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 67
总计 4,680
