跳转到主内容
Zotac EN970 Storage Replacement
你所需要的
  1. Zotac EN970 Storage Replacement, Opening your machine: 步骤 1 中的图像 1,2 Zotac EN970 Storage Replacement, Opening your machine: 步骤 1 中的图像 2,2
    • Zotac uses thumb screws to secure the case. No tools required!
    • After you remove the thumb screws, just slide the bottom cover away from you and lift it away.
  2. Zotac EN970 Storage Replacement, Insert your drive: 步骤 2 中的图像 1,3 Zotac EN970 Storage Replacement, Insert your drive: 步骤 2 中的图像 2,3 Zotac EN970 Storage Replacement, Insert your drive: 步骤 2 中的图像 3,3
    • The EN970 has three hard drive connectors: 2 2.5" bays and 1 M.2 bay.
    • There are thumb screws for the 2.5" drives that secure plastic caddies that snap onto your drive
  3. Zotac EN970 Storage Replacement, M.2 Drive: 步骤 3 中的图像 1,2 Zotac EN970 Storage Replacement, M.2 Drive: 步骤 3 中的图像 2,2
    • The M.2 drive requires a phillips screwdriver for installation. Your ZBOX should have two screws inserted in two of the three pegs.
    • Remove the screws, insert your drive and use one screw to secure it. Be sure not to over-tighten.
结论
9等其他人完成本指南。
zdowns1
于11/21/13注册
247 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 1,397
