跳转到主内容
Zoomer Show Pony Speaker Replacement
你所需要的
  1. Zoomer Show Pony Speaker Replacement, Power and Volume Switch: 步骤 1 中的图像 1,3 Zoomer Show Pony Speaker Replacement, Power and Volume Switch: 步骤 1 中的图像 2,3 Zoomer Show Pony Speaker Replacement, Power and Volume Switch: 步骤 1 中的图像 3,3
    • Flip the pony over.
    • Remove the five Triangle 3 screws from underneath.
    • The pony will separate into a few pieces once the screws are removed.
  2. Zoomer Show Pony Speaker Replacement: 步骤 2 中的图像 1,3 Zoomer Show Pony Speaker Replacement: 步骤 2 中的图像 2,3 Zoomer Show Pony Speaker Replacement: 步骤 2 中的图像 3,3
    • Disconnect all of the wires between the head and leg sections.
    • To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
    • Lift the switch out to replace.
  3. Zoomer Show Pony Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
  4. Zoomer Show Pony Speaker Replacement: 步骤 4 中的图像 1,2 Zoomer Show Pony Speaker Replacement: 步骤 4 中的图像 2,2
    • If you are not replacing the pony's speaker, skip the next bullet point.
    • Lift out the speaker, again making sure that it is disconnected, and replace with a new one.
结论
Matthew Sutton
于01/25/18注册
278 声望
创作了2篇指南
团队
USF Tampa, Team S20-G5, Passmore Spring 2018 USF Tampa, Team S20-G5, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 264
