跳转到主内容
Zoomer Show Pony Sensor Replacement
你所需要的
  1. Zoomer Show Pony Sensor Replacement, Sensor: 步骤 1 中的图像 1,3 Zoomer Show Pony Sensor Replacement, Sensor: 步骤 1 中的图像 2,3 Zoomer Show Pony Sensor Replacement, Sensor: 步骤 1 中的图像 3,3
    • Flip over your pony and find the screws marked in red.
    • Remove these screws with a 3.0 Triangle screw bit. Don't worry about keeping them seperated because they are all the same size.
    • When the screws are removed the head and rear legs should be removable. Be careful to not pull everything apart to much because the head and legs are all connected to the motherboard.
  2. Zoomer Show Pony Sensor Replacement: 步骤 2 中的图像 1,3 Zoomer Show Pony Sensor Replacement: 步骤 2 中的图像 2,3 Zoomer Show Pony Sensor Replacement: 步骤 2 中的图像 3,3
    • Remove the wires connecting the head and leg sections. We will disconnect all of the wire connections in this step and they will need to be re-connected at the end, so be careful when disconnecting.
    • Now that the wires have been disconnected, the head and back legs should be free to place aside
    • Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
  3. Zoomer Show Pony Sensor Replacement: 步骤 3 中的图像 1,3 Zoomer Show Pony Sensor Replacement: 步骤 3 中的图像 2,3 Zoomer Show Pony Sensor Replacement: 步骤 3 中的图像 3,3
    • Take out the two clips keeping the motherboard in place but applying upwards pressure on them.
    • Remove the motherboard and replace. The sensors are soldered on to the motherboard so the whole board must be replaced.
结论
另外一个人完成了本指南。
Cedric Bossa
于10/02/17注册
118 声望
撰写一个指南
团队
USF Tampa, Team S20-G5, Passmore Spring 2018 USF Tampa, Team S20-G5, Passmore Spring 2018 的会员
USFT-PASSMORE-S18S20G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 691
