跳转到主内容
Zoomer Meowzies Wheels Replacement
你所需要的
  1. Zoomer Meowzies Wheels Replacement, Legs: 步骤 1 中的图像 1,3 Zoomer Meowzies Wheels Replacement, Legs: 步骤 1 中的图像 2,3 Zoomer Meowzies Wheels Replacement, Legs: 步骤 1 中的图像 3,3
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Zoomer Meowzies Wheels Replacement: 步骤 2 中的图像 1,2 Zoomer Meowzies Wheels Replacement: 步骤 2 中的图像 2,2
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. Zoomer Meowzies Wheels Replacement: 步骤 3 中的图像 1,3 Zoomer Meowzies Wheels Replacement: 步骤 3 中的图像 2,3 Zoomer Meowzies Wheels Replacement: 步骤 3 中的图像 3,3
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
  4. Zoomer Meowzies Wheels Replacement, Wheels: 步骤 4 中的图像 1,1
    • Turn the Zoomer Meowzies leg to its side.
    • Using the Triangle driver remove the two bottom 7 mm screws.
  5. Zoomer Meowzies Wheels Replacement: 步骤 5 中的图像 1,1
    • Hold both sides of the leg and gently pull apart.
    • If pulled apart too forcefully the rest of the leg may sustain damage. Caution is advised.
  6. Zoomer Meowzies Wheels Replacement: 步骤 6 中的图像 1,2 Zoomer Meowzies Wheels Replacement: 步骤 6 中的图像 2,2
    • Wheel should now be exposed. Pull wheel up and away from the rest of the leg to remove. Replace with new wheel if necessary.
结论
Muataz Alahmadi
于02/14/18注册
193 声望
创作了2篇指南
团队
USF Tampa, Team S6-G2, Eyestone Spring 2018 USF Tampa, Team S6-G2, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S6G2
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 298
