跳转到主内容
Zoomer Meowzies Chest Senor Replacement
你所需要的
  1. Zoomer Meowzies Chest Senor Replacement, Legs: 步骤 1 中的图像 1,3 Zoomer Meowzies Chest Senor Replacement, Legs: 步骤 1 中的图像 2,3 Zoomer Meowzies Chest Senor Replacement, Legs: 步骤 1 中的图像 3,3
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Zoomer Meowzies Chest Senor Replacement: 步骤 2 中的图像 1,2 Zoomer Meowzies Chest Senor Replacement: 步骤 2 中的图像 2,2
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. Zoomer Meowzies Chest Senor Replacement: 步骤 3 中的图像 1,3 Zoomer Meowzies Chest Senor Replacement: 步骤 3 中的图像 2,3 Zoomer Meowzies Chest Senor Replacement: 步骤 3 中的图像 3,3
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
  4. Zoomer Meowzies Chest Senor Replacement, Chest Senor: 步骤 4 中的图像 1,3 Zoomer Meowzies Chest Senor Replacement, Chest Senor: 步骤 4 中的图像 2,3 Zoomer Meowzies Chest Senor Replacement, Chest Senor: 步骤 4 中的图像 3,3
    • Carefully pry the ribbon cable from the connector.
    • Though we find it easier to use our fingers, the pry-tools may be useful.
  5. Zoomer Meowzies Chest Senor Replacement: 步骤 5 中的图像 1,3 Zoomer Meowzies Chest Senor Replacement: 步骤 5 中的图像 2,3 Zoomer Meowzies Chest Senor Replacement: 步骤 5 中的图像 3,3
    • For easier access to the sensor, tilt and pull the sensor away from the body.
  6. Zoomer Meowzies Chest Senor Replacement: 步骤 6 中的图像 1,3 Zoomer Meowzies Chest Senor Replacement: 步骤 6 中的图像 2,3 Zoomer Meowzies Chest Senor Replacement: 步骤 6 中的图像 3,3
    • To remove the sensors, use a soldering iron to solder the two points and remove the red and black wires from the reverse side.
    • The soldering iron is very hot, so take caution not to touch it directly in order to avoid burns.
  7. Zoomer Meowzies Chest Senor Replacement: 步骤 7 中的图像 1,2 Zoomer Meowzies Chest Senor Replacement: 步骤 7 中的图像 2,2
    • Turn the sensors over and locate the solder points of the remaining white wires. Heat the solder and remove the pair of wires.
    • The sensor should be completely detachable now.
结论
Mitchell Gentry
于02/14/18注册
675 声望
创作了6篇指南
团队
USF Tampa, Team S6-G2, Eyestone Spring 2018 USF Tampa, Team S6-G2, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S6G2
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 461
