跳转到主内容
Zoomer Meowzies Battery Replacement
你所需要的
  1. Zoomer Meowzies Battery Replacement, Battery: 步骤 1 中的图像 1,2 Zoomer Meowzies Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the Zoomer Meowzies over so it is on its back and its stomach is facing up.
    • Using the Phillips #1 screwdriver, loosen the screw holding the battery compartment closed.
    • This screw has a collar that will prevent it from being completely removed and therefore cannot be measured or replaced.
  2. Zoomer Meowzies Battery Replacement: 步骤 2 中的图像 1,2 Zoomer Meowzies Battery Replacement: 步骤 2 中的图像 2,2
    • Lift the compartment cover from the body. Due to the ribbon on the cover, the batteries should pop out as you remove the cover.
    • Replace with new batteries using the diagrams located within the compartment as a guide for correct battery orientation.
    • When replacing the batteries, weave the ribbon under each battery for easy removal later.
结论
Mitchell Gentry
于02/14/18注册
675 声望
创作了6篇指南
团队
USF Tampa, Team S6-G2, Eyestone Spring 2018 USF Tampa, Team S6-G2, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S6G2
3 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 859
