跳转到主内容
Zoomer Jurassic World Indominus Rex Nose Sensors Replacement
你所需要的
  1. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Mouth Part: 步骤 1 中的图像 1,2 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Mouth Part: 步骤 1 中的图像 2,2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: 步骤 2 中的图像 1,3 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: 步骤 2 中的图像 2,3 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: 步骤 2 中的图像 3,3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Nose Sensors: 步骤 3 中的图像 1,2 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Nose Sensors: 步骤 3 中的图像 2,2
    • Carefully, pull out the circuit board that has the three nose sensors attached.
    • You're almost done! The only thing left to do is to use a soldering iron to remove the six (6) wires connected to the circuit board.
    • Use caution when soldering to avoid being burned.
结论
2等其他人完成本指南。
Luke Selby
于01/20/16注册
624 声望
创作了4篇指南
团队
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G3
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 362
