跳转到主内容
Zoomer Jurassic World Indominus Rex Mouth Part Replacement
你所需要的
  1. Zoomer Jurassic World Indominus Rex Mouth Part Replacement, Mouth Part: 步骤 1 中的图像 1,2 Zoomer Jurassic World Indominus Rex Mouth Part Replacement, Mouth Part: 步骤 1 中的图像 2,2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Mouth Part Replacement: 步骤 2 中的图像 1,3 Zoomer Jurassic World Indominus Rex Mouth Part Replacement: 步骤 2 中的图像 2,3 Zoomer Jurassic World Indominus Rex Mouth Part Replacement: 步骤 2 中的图像 3,3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
结论
Anh Le
于01/20/16注册
504 声望
创作了3篇指南
团队
USF Tampa, Team 10-3, Remmell Spring 2016 USF Tampa, Team 10-3, Remmell Spring 2016 的会员
USFT-REMMELL-S16S10G3
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,130
